Get access to all standard record information of a PIO?
VvierA
Hello,
I'd like to get access via Vectorscript to all standard record information.
A path object for example:
I can get LineLength which is a standard parameter in the parameter list of the PIO object.
But in the object info palette there is also:
x coordinate
y coordinate
z coordinate
angle
Where do I find this variables?
Do I have to use 'GetSymLoc' to get x and y? But how do I get z and the angle?
Kind regards
VvierA
  • 2 months later...
If you want to save that information in an object's parameter you use this function:
SetRField
In a PIO's case, the record name is the objects name
SetRField(HandleToObject,object/recordname,recordfield/parametername,value);
With GetRfield you can retrieve values.
You can also get the parameter values in the code of an object trough:
MyString :PPARAMETER1;
This will load your PIO parameters in variables so you can use them in your script. GetRField will also work, but this is easier.
Edited by hippothamus
