johnharley Posted November 8, 2012 Share Posted November 8, 2012 How do you adjust the size of the font used in the property line tool annotations? The font size for the bearings and distances are microscopic. Using VX 2013, Landmark (win). 1 Quote Link to comment
Guest nigel.c Posted November 12, 2012 Share Posted November 12, 2012 [in Windows] Select the property line/s and punch ALT x s (MENU teXt>Size) and enter a size on the dropdown. Also modify your signature to show your OS and version of VW - you'll get more answers Property Line objects could be most useful, instead due to Nemetschek's intransigence they are quite annoying. They are also VERY poorly documented. I once did a subdivision with 50 lots that was much more of a learning curve than it should've been. Quote Link to comment
Jonathan Pickup Posted November 13, 2012 Share Posted November 13, 2012 You can also use a Text Style to control the text on the Property Line. That way you can chage the font, size, style and color. Quote Link to comment
Jonathan Pickup Posted November 13, 2012 Share Posted November 13, 2012 movie: http://learn.archoncad.com/2012/11/10090/podcast142-editing-property-line-text-size/ Quote Link to comment
Ian M. Posted June 30, 2022 Share Posted June 30, 2022 I want to give the property line a fill color, and give that fill a transparency, but the transparency is applied to the entire property line object including the boundary line and annotations. Other Vectorworks objects seem to understand the attributes palette's instructions regarding "Fill" vs. "Line" - am I missing something, or is this just another piece that is not fully integrated? Quote Link to comment
Ian M. Posted March 26 Share Posted March 26 @Jonathan Pickup Do you know if there is a way to edit the attributes of a property line object? I would like to give it a semi-transparent fill, but keep the text as is, but the transparency option for the fill affects the entire property line object, including the text. Alternatively, is there another tool that will measure and display the area, name, etc. assigned? Thank you. Prop line tool.pdf Quote Link to comment
