VincentCuclair Posted November 1, 2012 Share Posted November 1, 2012 (edited) Is this the correct way to show hinge direction in the US? Or is the hardware on the wrong side? (In Sweden and Holland the wide side of the 'arrow' defines the 'hinge' side ie. the opposite of how it is in the Door tool!?) Edited November 1, 2012 by Vincent C Quote Link to comment
Christiaan Posted November 1, 2012 Share Posted November 1, 2012 Yeah it's different in different countries. Better add they to needleandmortar quick. Quote Link to comment
VincentCuclair Posted November 1, 2012 Author Share Posted November 1, 2012 Done...... Quote Link to comment
Peter van der Elst Posted November 2, 2012 Share Posted November 2, 2012 Hi Vincent, In the Vectorworks library (application folder) there's folder called plugins-Common-Data-Doorpreferences.xml. You can open this and there's a line called hingepref (at the bottom) Here you can set a us (0) or non-US (1) standard. You type this number between so that it reads 1. Restart VW and it should work. I spend an afternoon trying to figure out where to change this. Ofcourse not in the OIP or dialog....... Quote Link to comment
VincentCuclair Posted November 2, 2012 Author Share Posted November 2, 2012 (edited) Perfect! Bedankt! In 2012 it was already set.......I guess it wasn't set in 2013 because it is the evaluation version....... Edited November 2, 2012 by Vincent C Quote Link to comment
Kevin McAllister Posted November 2, 2012 Share Posted November 2, 2012 Wow, that's an obscure preference! Not sure how anyone would find that. KM Quote Link to comment
Jonathan Pickup Posted June 5, 2013 Share Posted June 5, 2013 Hi Vincent, In the Vectorworks library (application folder) there's folder called plugins-Common-Data-Doorpreferences.xml. You can open this and there's a line called hingepref (at the bottom) Here you can set a us (0) or non-US (1) standard. You type this number between so that it reads 1. for windows, look for the preference called: WindowPreferences.xml edit this: Quote Link to comment
Kizza Posted June 5, 2013 Share Posted June 5, 2013 Unfortunately it doesn't work for windows (works fine for doors) Quote Link to comment
Jonathan Pickup Posted June 5, 2013 Share Posted June 5, 2013 Please report this as a bug then Quote Link to comment
VincentCuclair Posted June 11, 2013 Author Share Posted June 11, 2013 Anyone know if there is a similar file/method/script for making the default break for windows/doors to 'full break with caps'? Quote Link to comment
Bas Vellekoop Posted July 6, 2013 Share Posted July 6, 2013 I changend the xml-file. In new files it is working fine but in existing ones not... what to do?... Quote Link to comment
Assembly Posted July 7, 2013 Share Posted July 7, 2013 You have got to be kidding me... Editing a .xml file to set preferences, Talk about half baked software! Quote Link to comment
