Thom Posted November 1, 2012 Share Posted November 1, 2012 (edited) Is there a routine for this. Much of what I do for irrigation design involves coping a symbol, placing and rotating. Edited November 1, 2012 by Thom Quote Link to comment
CipesDesign Posted November 1, 2012 Share Posted November 1, 2012 Hi Thom, If it is a 90? or 180? rotation you can use keyboard shortcuts for 90? L (control L) or 90? R (control shift R). Other than that I don't know of any existing command. But I'll bet a script could be written. The other thing you might find useful is the option to Rotate Duplicates in the Duplicate Array command... But if course this only works if your duplications AND rotations are even and repeating... Quote Link to comment
Bryan G. Posted November 4, 2012 Share Posted November 4, 2012 Thom, as I have stated before. We need an appropriate irrigation design module. Quote Link to comment
bcd Posted November 4, 2012 Share Posted November 4, 2012 Use the Create Similar tool Alt + Ctrl (win) or Opt+Cmd (mac) click to select the symbol One click to place Second click to set the new rotation Quote Link to comment
Jonathan Pickup Posted November 4, 2012 Share Posted November 4, 2012 As bcd says, the Create Similar Object... It is a great productivity technique Quote Link to comment
Bryan G. Posted November 4, 2012 Share Posted November 4, 2012 These are great but when it comes to irrigation design the ability to initially select the spray radius then click to set head then click to set one fixed side then click to set final side. this would be the best option for layout. Although a faded full circle as a guide would also help. The problem here is I can get VW to do anything but in many instances it is not efficient to work in the give parameters of the program as it is now. Thus we need an irrigation module. Quote Link to comment
Jonathan Pickup Posted November 4, 2012 Share Posted November 4, 2012 I have heard others ask for a dedicated Irrigation module. Quote Link to comment
Thom Posted November 7, 2012 Author Share Posted November 7, 2012 Where is the create similar tool. Does not show up in help. Quote Link to comment
CipesDesign Posted November 7, 2012 Share Posted November 7, 2012 Hi Again, Here ya go: Quote Link to comment
