Matthew Giampapa Posted August 9, 2002 Share Posted August 9, 2002 You need specify what's broken first. Hatches should be printing correctly from VW 9 with black background. Typically to check something like this we need, OS / VW version / Printer / Driver version. Matthew GiampapaNNA Technical Support Quote Link to comment
TiTaNiuM sAMuRai Posted August 9, 2002 Author Share Posted August 9, 2002 Ukayyy.McOS9.1 thru McOSX.1.5VW 8.5.2 thru 9.5.2 (incl. all releases and betas in between)HP LaserJet 4MV (postscript laser printer) (with an older, then the latest driver)HP DesignJet 500 PS (via MacPlot RIP) Three situations for testing, all with no background fill in the hatch:1- default hatch, b&w OFF: correct2- coloured hatch lines, b&w OFF: correct3- default hatch, b&w ON: correct4- coloured hatch lines, b&w ON: INCORRECT -> hatch lines are drawn white Turn ON the background fill,5- coloured hatch lines, b&w ON: INCORRECT -> hatch lines are drawn white I had this same problem on another computer (the OS9 running 8.5.2, with the older LaserJet driver) Check if PenFore and PenBack are mixed up in VS, too. Quote Link to comment
TiTaNiuM sAMuRai Posted August 10, 2002 Author Share Posted August 10, 2002 When will printed hatches be fixed from a black background (B&W on)? Quote Link to comment
