Teigha library error
beave
  • 4 months later...
  • 2 weeks later...
  • 11 months later...
I have had users encounter this for a number of reasons, the most common being these:
1) The DWG version is too new, OR includes a plugin that isnt supported by the older Vectorworks' DWG import. Which can result in ACAD 2012 or 2013 exporting a DWG file that actually registers as a 2014DWG.
2) The DWG file simply needs to be renamed (to anything else, doesnt seem to matter) or relocated as mentioned in the above post, which then allows it to import.
3) The ACAD user will need to export as 2010 or an older format, then the files seem to import fine, regardless of the plugins mentioned in 1.
I had not seen http://www.opendesign.com/guestfiles/TeighaFileConverter until now, thank you BCEM. I will experiment with it and if it works out as a solution, create a kbase article explaining its use in order to get around this problem.
  • 4 years later...
  • 1 year later...
