Craig D.S.
best method of inserting Excel Data into a Site Model
Pasting the data into a text file, and Import Survey File does not seem to import all cell data.
So what are the best ways to import one's Excel spreadsheet data into a Site model
export the text file as a simple text document with the following format:
id Northing Easting Elevation Description
nothing else.
then use the import survey command.
Thanks for replying Jonathan.
I should have stated that the Excel file has only Z height values, and is not the regular survey data file.
that was why I was having trouble in this case.
I can open the tab delineated text file in AccuTrans 3D, save it as a DXF, import that into VW and build the site model around that data.
There does not seem to be an internal way to only insert Z height values...
As I'm not very familiar with survey files...How do I insert the extra fields for the" id Northing Easting Elevation Description
is ID from 0 to n-1?
Can Northing and Easting be 0,1,2 etc
And I'm not uure of description
I guess I'd better study up on this.
let me first start by asking do you have a survey file from a surveyor? Or are you generating this from scratch.
I'm generating this myself, from spot elevations a metre apart, to make a 21x21 or 25x25 grid, which can then be visualized in 3D Surface Charts
