Thom Posted October 16, 2012 Share Posted October 16, 2012 In the old days, we used to have a routine that when one clicked on a line, the class would turn off. Is there still a routine out there? I get files that have hundreds of classes and it is tough to figure out what to turn off. Quote Link to comment
Bruce Kieffer Posted October 16, 2012 Share Posted October 16, 2012 Thom, When you select an object, the Object Info Palette will show you what class it's in. You can use the Visibility Tool to quickly highlight all visible objects in the same class (I think this is what you want). You can use the Select Similar tool to select visible objects with predefined similarities (settings). And you can turn individual classes on or off in the Navigation Palette. Quote Link to comment
VincentCuclair Posted October 17, 2012 Share Posted October 17, 2012 You can turn off individual classes or layers directly using the Visibility tool. Quote Link to comment
Thom Posted October 17, 2012 Author Share Posted October 17, 2012 Bruce - thks, I knew about your information. Vincent - Did not realize that the Visibility tool would turn off classes. Just what I was looking for. thks to both of you Quote Link to comment
