hdu change the default options in the attribute pallette
Hi allHow does one change the default options for lineweights in the attribute pallette?I have the lineweights displaying in mm, which is good for a metric thinker like myself, but what I really wanna do is have the following line-weights available for 'quick select';.3 .9 .15 .2 .25 .3 .35 .5 .7
Currently I have these options;.0 .3 .15 .3 .5 1.02
Any ideas?
And if you can solve this, what about doing a similar thing for text sizes?
Thanks
Mat, As it is currently, you can only have 5 options for line thickness and 0 points. The 0 line thickness you can't change. The other 5 you can change thru the Page menu, set attribute defaults, which I am assuming you have already discovered.
Have the option to set more than 5 settings is something that has been added to the wish list.
