Hippocode Posted October 12, 2012 Share Posted October 12, 2012 While trying to make my custom space PIO I can't manage to name the polyline inside my PIO. ( This for use of the location selection critera ) The objecthandle will name the PIO itself, but not the polyline in it, The LNewObj doesn't do anything, and the pathHd of the object can have a name, but that's useless. am I overlooking smth ? Quote Link to comment
maarten. Posted October 12, 2012 Share Posted October 12, 2012 I think you can not name an object inside a PIO because when you place a second instance of your PIO, the name of your poly inside your PIO will already excist in the drawing. with symbols, you can do such things though, because the object will only excist ones in the symbol definition. I can be wrong, so don't shoot me if I am . Quote Link to comment
Vectorworks, Inc Employee klinzey Posted October 12, 2012 Vectorworks, Inc Employee Share Posted October 12, 2012 All names in the document need to be unique. You should be able to name objects within a PIO but they have to be unique in the document including names of class, symbols, textures etc. The simplest way to do this is use GetObject() or Name2Index() to make sure the name is not in use. Quote Link to comment
Miguel Barrera Posted October 12, 2012 Share Posted October 12, 2012 The simplest way is to add a parameter to name it. Since the parameter is a field in the pio record, you can use the field value criteria to use in worksheets, etc. Quote Link to comment
Hippocode Posted October 15, 2012 Author Share Posted October 15, 2012 Adding a parameter is not what I'm looking for. I need to name an object ( the polyline in this case ) so it can be used as a location. I've been trying something and these are the non-working results. - naming the path works - naming the polyline doesn't work. So I thought I didn't have the handle right. I create a text object, get a handle to it with LNewObj and name it within the script. Doesn't work either. All I can name is the PIO itself, and the handle of the PIO. Everything else returns an empty name slot Quote Link to comment
Miguel Barrera Posted October 15, 2012 Share Posted October 15, 2012 By holding the name in a record field has the same effect as naming the object directly because it is contained within the pio. But if not desired then: 1. What are you trying to achieve by naming the object? 2. Where are you going to use the name? Quote Link to comment
JBenghiat Posted October 16, 2012 Share Posted October 16, 2012 I imagine the issue you are having is that each name must be unique or that setname worked, but you can't see that it did. PIO regen code can run a few times during insertion, so the only way to guarantee a unique name is for the code to check for one. That said, there may be a more elegant solution than using Location and criteria. Have you looked at http://developer.vectorworks.net/index.php?title=VS:PtInPoly and http://developer.vectorworks.net/index.php?title=VS:PtInRect? -Josh Quote Link to comment
Hippocode Posted October 19, 2012 Author Share Posted October 19, 2012 (edited) Well, The name is unique and does get checked before added, but still I can't name any objects inside a PIO besides the path of the 2d path object. With getobject I check it to return NIL ( which it does ), but it doesn't add the name to the fresh polyline. I guess its impossible then Why and how I want it to work: -space 2d object lets you make a frame for a room. -Popup asks a roomnumber and name ( these together form the name ) -The name gets inserted in the polyline of the object ( which I can't manage) -After that, another script will get trough all the spaces and use the name as a location criteria, so it can select all symbols in that space. PtInPoly can't be used for it, as the PIO isn't a standalone poly. PROCEDURE objectos; CONST kObjXPropSpecialEdit = 3; kReshapeSpecialEdit = 3; kObjXIs2DSurfaceEligible = 14; kObjXPropEditGroup = 1; kObjXPropEditGroupPath = 2; kObjOnInitXProperties = 5; kResetEventID = 3; VAR theEvent, theButton :LONGINT; status :BOOLEAN; PROCEDURE Main; VAR pathHd,objHd,objrecHd,wHd,PHd,TempHd :HANDLE; result :BOOLEAN; objName :STRING; num_vertices,i :INTEGER; seg_angle :REAL; dir_vec :VECTOR; v1x,v1y,v2x,v2y,mx,my :REAL; t1x,t1y,t2x,t2y,tdx,tdy :REAL; x,y :REAL; vertexType :INTEGER; vertexRadius :REAL; ShowDN :BOOLEAN; positie,i_DN,FontSize :INTEGER; request1,request2,result1,result2,RuimteNaam,RuimteNummer:STRING; name,klasse,temp: STRING; BEGIN { retrieve plug-in object information } result:= GetCustomObjectInfo(objName,objHd,objrecHd,wHd); { if the plug-in object info was successfully retrieved } IF result THEN BEGIN { retrieve the parameter settings for the object } RuimteNaam := PSPACENAME; RuimteNummer := PSPACENUMBER; { Juiste klasse selecteren } klasse:='TDE-60 sanitair-koud'; NameClass(klasse); { obtain a handle to the path polygon of the object } pathHd:= GetCustomObjectPath(objHd); { get the number of vertices in the path } num_vertices:= GetVertNum(pathHd); { draw the piping lines and text label } BeginPoly; IF num_vertices = 2 THEN BEGIN i:=2; GetPolyPt(pathHd,i,v2x,v2y); GetPolyPt(pathHd,i - 1,v1x,v1y); MoveTo(v1x,v1y); {LineTo(v2x,v2y);} AddPoint(v2x,v2y); END; FOR i:= 2 TO num_vertices DO BEGIN GetPolyPt(pathHd,i,v2x,v2y); GetPolyPt(pathHd,i - 1,v1x,v1y); MoveTo(v1x,v1y); IF num_vertices <> 2 THEN AddPoint(v2x,v2y); END; EndPoly; END; SetPolyClosed(LNewObj, True); request1 := 'Geef het lokaalnummer in:'; request2 := 'Geef de ruimtenaam in:'; IF RuimteNummer = '' THEN BEGIN result1:=StrDialog(request1,RuimteNummer); SetRField(ObjHd,ObjName,'SpaceNumber',result1); END ELSE BEGIN result1:=RuimteNummer; END; IF RuimteNaam = '' THEN BEGIN result2:=StrDialog(request2,RuimteNaam); SetRField(ObjHd,ObjName,'SpaceName',result2); END ELSE BEGIN result2:=RuimteNaam; END; name:=concat(result1,': ',result2); TempHd := GetObject(name); IF TempHd = NIL THEN BEGIN SetName(LNewObj,name); Message('object name is unique, send it to the polyline :('); END; {Add Text} HCenter(LNewObj,x,y); { set the text properties } TextSize(10); TextJust(2); TextVerticalAlign(3); TextOrigin(x,y); CreateText(name); END; BEGIN vsoGetEventInfo(theEvent, theButton); CASE theEvent OF kObjOnInitXProperties: BEGIN status:=SetObjPropCharVS(kObjXPropSpecialEdit,Chr(kReshapeSpecialEdit)); status:=SetObjPropVS(kObjXIs2DSurfaceEligible,TRUE); status:=SetObjPropCharVS(kObjXPropEditGroup,Chr(kObjXPropEditGroupPath)); status:=vsoInsertAllParams; END; kResetEventID: BEGIN Main; END; END; END; RUN(objectos); Edited October 19, 2012 by hippothamus Quote Link to comment
Dieter @ DWorks Posted October 19, 2012 Share Posted October 19, 2012 -The name gets inserted in the polyline of the object ( which I can't manage) Use a pio parameter for storing this info. Use a text object for showing the info. PtInPoly can't be used for it, as the PIO isn't a standalone poly. You can get the path of the pio, with that and the insertion point of the pio, you can use PtInPoly, though it can be that you have to draw the poly of the pio and then delete it afterwards. Quote Link to comment
Miguel Barrera Posted October 21, 2012 Share Posted October 21, 2012 You are making it more omplicated than it should. You are already half way there with the path object but asking for information from the user with a dialog when it can be entered in the OIP. Besides the dialog will show up every time the object is regenerated. To make the code cleaner I would add a third hidden parameter to hold the full name as in: fullName:= Concat(RuimteNummer,':',RuimteNaam); SetRField(ObjHd,ObjName,'__HiddenField',fullName); To find the symbols in space '301:Room Name' on a separate script: PROCEDURE FindSyms; VAR spaceHdl,polyHdl: HANDLE; PROCEDURE GetSpace(objHdl: HANDLE); BEGIN spaceHdl:= objHdl; END; PROCEDURE GetSyms(symHdl: HANDLE); VAR symPt: POINT; BEGIN GetSymLoc(symHdl,symPt.x,symPt.y); IF PtInPoly(symPt.x,symPt.y,polyHdl) THEN BEGIN { Process the symbol inside the space pio further } ......... ......... END; END; BEGIN ForEachObject(GetSpace,(('Pio Name'.'__HiddenField'='301:Room Name'))); IF spaceHdl <> NIL THEN BEGIN polyHdl:= GetCustomObjectPath(spaceHdl); {This will get all symbols but it can be modified to limit only the ones in the active layer } ForEachObject(GetSyms,((T=SYMBOL))); END; END; This code could also be triggered by a button parameter in the OIP if desired. Quote Link to comment
Hippocode Posted October 23, 2012 Author Share Posted October 23, 2012 Hey, Thanks for the great responses. I changed the space script with your suggestions and I tweaked your script to find symbols in a room. I do encounter a problem comparing the coordinates though. Maybe becuase the coordinates of the path are relative to the insertion point of the space object ? Once I get this to work I will turn around the code, so its searches all the symbols and compares them to all spaces. Because like this it checks every symbol way to many times Procedure FindSymbols; VAR SpaceHandle,PolyHandle: HANDLE; i,j: INTEGER; temp_string: STRING; p1x,p2x,p1y,p2y: REAL; PROCEDURE GetSpace(ObjHandle:HANDLE); FUNCTION GetSymbols(SymHandle:HANDLE) :BOOLEAN; VAR symPt: POINT; SymbolName: STRING; BEGIN GetSymLoc(SymHandle,symPt.x,symPt.y); SymbolName:=GetSymName(SymHandle); IF PtInPoly(symPt.x,symPt.y,PolyHandle) AND (SymbolName <>'') THEN BEGIN AlrtDialog(concat(SymbolName,': x=',symPt.x,' y=',symPt.y)); END; END; BEGIN SpaceHandle:= ObjHandle; { space found } IF SpaceHandle <> NIL THEN BEGIN { Get the path } PolyHandle:=GetCustomObjectPath(SpaceHandle); { GetBBox(PolyHandle,p1x,p1y,p2x,p2y); Message('p1x: ',p1x,', p1y: ',p1y,' p2x: ',p2x,' p2y: ',p2y);} { Only get all the objects in the current layer } ForEachObjectInLayer(GetSymbols,0,2,0); END; END; BEGIN { Loop trough each custom space object } ForEachObject(GetSpace,((PON='TDE_Space'))); END; Run(FindSymbols); Quote Link to comment
