obj. info palette dimensions
Are you referring to the width, depth and height, or are you referring to the x and y and delta x and y ?
What type of objects do you have in groups?Are they different kinds of objects - solid subtractions, symbols, 2d objects, 3 objects, etc. ?
If you have 2d objects grouped and switch to any sort of 3d view, including Top, then you will not get the x,y and delta x and y settings in the OIP. Once you switch to TOP/PLAN view you should see these boxes. The same holds true for some plugins and symbols becuase of thier hybrid nature.
