Walls mustn't move when replacing style
Christiaan
7 answers to this question
It's usually when you have three-wall join but it can be a series of of other joins on the wall somewhere that lock it in place. You can't drag these walls without breaking the relevant wall join for instance.
And when you replace the wall style it ignores your choice of alignment and simply aligns to the centre of the wall.
Did I say critical?
Nemetschek, we've got to be able to trust that Vectorworks won't move walls just because we've added or removed a component. We can't afford to be going around an entire project checking wall positions every time we edit a wall style.
Apart from being inaccurate we look like [expletive] idiots when the contractor has updated set out drawings where walls have moved by 7 mm! Ughh.
