joerg Posted October 10, 2012 Share Posted October 10, 2012 (edited) i made a drawing with rectangles in layerplane because i wanted the lines rendered, and want to render in custom renderworks looks fine in designlayer looks terrible in viewport (150dpi) is there a trick? i know i can do it in 3D-poligon and no lines, but just want to know the reason for that...! Edited October 10, 2012 by joerg Quote Link to comment
CipesDesign Posted October 10, 2012 Share Posted October 10, 2012 Try increasing the DPI of the Sheet Layer. Quote Link to comment
ray isaacs Posted October 10, 2012 Share Posted October 10, 2012 this has happened to me, too. the default resolution for sheet layers is 72 dpi. if you don't remember to set it higher, you will get pixelated renderings. Quote Link to comment
Horst M. Posted October 11, 2012 Share Posted October 11, 2012 (edited) Hallo J?rg, I' see that effect too, it happens on 2d Layerplane Objects in a Renderings. In the attached rendering I forgot to switch of the Gudes Class, that contains some 2D Objects, that I needed for Construction. The rendering with the piexation is a Renderworks Style "Exterior Final". The Lines render correctly in Final Quality RW Horst M. Its done in VW2013 Evaluation. Edited October 11, 2012 by Horst M. Quote Link to comment
joerg Posted October 11, 2012 Author Share Posted October 11, 2012 thanks for your answers! i had the sheetlayer set to 150 dpi and increasing it to a 600dpi would also multiply rendertimes....! Well there is allways a workarround and i used my old trick. i duplicated the viewport set to hiddenline rendering and after updating converted to lines, delate or add lines, than transparency to 40% voila.. i like that look it's more like a model Quote Link to comment
