Vincent C Posted October 5, 2012 Share Posted October 5, 2012 Is it possible to change a Sheet Number and/or Title through a worksheet? Anyone? Quote Link to comment
Dieter @ DWorks Posted October 5, 2012 Share Posted October 5, 2012 Nope. I also tried it. Quote Link to comment
JoeStewart Posted October 16, 2012 Share Posted October 16, 2012 Yes. Create a custom title block. The sheet number should have a suffix of _SN and the sheet title _SD. Good luck. Quote Link to comment
Vincent C Posted October 16, 2012 Author Share Posted October 16, 2012 (edited) Yes. Create a custom title block. The sheet number should have a suffix of _SN and the sheet title _SD. Good luck. No, you still can't change it from the worksheet..... Edited October 16, 2012 by Vincent C Quote Link to comment
Bryan G. Posted October 17, 2012 Share Posted October 17, 2012 from a worksheet? No! although this would be a nice addition to the worksheet functionality. Quote Link to comment
michaelk Posted October 17, 2012 Share Posted October 17, 2012 I could have finally gone off my rocker, but I swear this used to work.... Don't remember which version, but I clearly remember enjoying this capability and noticing that it had stopped working. ...or it's that off the rocker thing.... mk Quote Link to comment
Joey Parsonson Posted November 13, 2012 Share Posted November 13, 2012 I can get it to work in VW2012 by having custom title block as a sheet border on each sheet layer with record formats as Joe stewart mentioned above. Create a report. Name sheet. List all: objects with a record Listing objects with record: Title block format (or whatever you called your record format for custom title block) Add sheet number & sheet title formats from left column to right column. Click OK. All done, BUT??? my sheet numbers aren't in order say from sheet 001 to sheet 034 it will list them in the worksheet randomly. Any ideas??? I got this far, would be great to finish & use. Quote Link to comment
michaelk Posted November 14, 2012 Share Posted November 14, 2012 Apply a sort. Click on a database row header (i.e., x.xx row) The sort icon will change from gray to black. Drag the sort icon to the row you want to sort by. hth mk Quote Link to comment
