I would like to see the Select Similar Tool with the same type of functions as the Custom Selection Command.
eg. I want to be able to select all windows with the same ID and I want to be able to quickly access the saved selection criteria later as it is in the Select Similar tool.
Yes, I know that the Custom Selection Command can create a script that can be accessed later, however if I have 200+ windows and doors and need to create a script for each to be accessed later my clients will have moved to another architect and the building will be half done by the time I get that far.....
What I want is to simply be able to choose ID (or frame thickness or fire-rating or certain record term or what ever) as the search criteria in the Select Similar tool dialog and then click on the object to select all........and I want to be able to save the criteria combination for later use.
Basically a merger of the Select Similar and the Custom Selection!
VincentCuclair
5 answers to this question
