brent m kjernisted Posted October 4, 2012 Share Posted October 4, 2012 I can't get the split tool to work, in point split mode, on walls. In line split mode it will cut the walls, but you are not able to lengthen or join these walls, after this operation. Quote Link to comment
brent m kjernisted Posted October 4, 2012 Author Share Posted October 4, 2012 In the line split mode the wall is converted to solids. Nothing happens in point split mode. It is the point split mode I am having trouble with. Nothing happens. Thanks Quote Link to comment
Guest Wes Gardner Posted October 4, 2012 Share Posted October 4, 2012 I'm not seeing that, mine appears to work as designed...anyone else? Quote Link to comment
brent m kjernisted Posted October 4, 2012 Author Share Posted October 4, 2012 Thanks for taking the time to look at this problem. Fortunately my distributor was able to tell me it would not work in plan3d mode. I sent him the file and a half hour later he had the answer. Next time I'll post the file as I'm sure someone on the forum would have been able to provide me with the same answer. Cheers Quote Link to comment
