(Auto) Update Fit Walls to Objects
VincentCuclair
I would like to see the introduction of an (auto)update function connected to the Fit Walls to Objects command.
eg. At the moment if the objects are changed, all affected walls need to be selected individually (it is not always clear which walls have been effected either) and then the command needs to be rerun.
It would save a lot of time and remove a large margin of error if:
1- It was clear what walls have been effected by a change in the 'objects',
2- There was a general update/rerun command for affected walls after a change in the 'objects',
3- If there was an auto update function attached to the walls that have been manipulated by the Fit Walls to Objects command.
4- And the addition of a Reset Wall Tops command would be appreciated.
Edited by Vincent C
3 answers to this question
