Kronur Posted September 26, 2012 Share Posted September 26, 2012 I use the fillet dialog *all the time* in my drafting. Now that I've upgraded to Vectorworks 2013, my beloved keyboard shortcut command does not open the fillet dialog box. All the other dialog boxes (offset, align/distribute objects, eyedropper preferences) are still around. Where did fillet run off to? Quote Link to comment
Jonathan Pickup Posted September 26, 2012 Share Posted September 26, 2012 You do not need the dialog box any longer, you can type the information directly onto the toolbar. Quote Link to comment
VectorGeek Posted September 26, 2012 Share Posted September 26, 2012 Jonathan is right...however: What is missing is a long-standing feature that allowed you to double-click an object with the Fillet Tool. The result was that all corners were filleted at once. This was handy and is now gone, unless I am missing something. V-G ------------------------------------- "Bill The Cat 2012" Quote Link to comment
Kronur Posted September 26, 2012 Author Share Posted September 26, 2012 Yes, but typing into the toolbar is more complicated and takes loads more time. I have to type [f] to navigate to the fillet tool, then another [key] for Group 2 Navigation, instead of the very quick [ff]. Analogous example: One can also type the offset distance into the toolbar, but the dialog box still exists [mm] and is the faster way to do things. Quote Link to comment
VectorGeek Posted September 26, 2012 Share Posted September 26, 2012 Wait a minute....... Before 2013:: 1) Type "FF" (or whatever the tool shortcut was, but twice to open the dialog) 2) Type in the value 3) Press "Return" In 2013: 1) Type "F" (or whatever the tool shortcut is, but just once) 2) Type "I" (or whatever the second mode shortcut is) 3) Type in the value So in essence, we're talking about using "FI" instead of "FF", with no more need to press "Return" to dismiss a modal dialog box. And this change is "more complicated" and takes "loads more time"? Yikes. Quote Link to comment
Kronur Posted September 27, 2012 Author Share Posted September 27, 2012 It's a waste of time to debate the usefulness or reliability of keyboard shortcuts; some people don't use them and spend their drafting hours navigating drop-down menus. Quite honestly, in the four days I've been using 2013, I'm almost as fast with the new method. For me, the question still remains: Why remove the fillet dialog, but not the offset dialog? Where's the consistency in design and implementation in this software? I've been using VW for 9 years, and I'm a big fan, but this lack of uniformity in execution is puzzling. (Did they mean to remove the offset dialog, but forgot? Did the fillet dialog get overlooked? Are all dialogs on the chopping block in future, more robust upgrades?) Quote Link to comment
GWS Posted September 27, 2012 Share Posted September 27, 2012 What is missing is a long-standing feature that allowed you to double-click an object with the Fillet Tool. The result was that all corners were filleted at once. This still works in 2013. Quote Link to comment
mike m oz Posted September 27, 2012 Share Posted September 27, 2012 For it to work you need to have the Fillet tool selected and set with the radius you want. You then need to go to an edge and once it has hilighted quickly double click on the edge. That will fillet all of the corners of the object. Quote Link to comment
VectorGeek Posted September 27, 2012 Share Posted September 27, 2012 What is missing is a long-standing feature that allowed you to double-click an object with the Fillet Tool. The result was that all corners were filleted at once. This still works in 2013. It does. When I tested yesterday it was not working. Restarted VW and works like a peach, and exactly as before. VG. Quote Link to comment
