Push/Pull tool
GWS
10 answers to this question
Guy, the Push-Pull tool has three modes. The only one which produces a Generic Solid is the Move Face mode. The Extrude Face Mode and Sub-face mode both produce solids with a history.
Therefore if you form a hole using the Sub-face mode you can edit the 'solid' (ie. its history) and change the size of the object which formed the hole.
.... ie being able to grab the hole and adjust its size directly rather than editing the history. That is certainly the way some of the high end mechanical programs are going.
Agreed Mike, I use other software as well as VW but I somehow doubt that VW will implement that kind of feature while some of the more basic stuff is still omitted.
