Vincent C Posted September 24, 2012 Share Posted September 24, 2012 Well guys? Anyone tried out 2013 in depth yet, what are your thoughts so far? Quote Link to comment
Bryan G. Posted September 24, 2012 Share Posted September 24, 2012 So far so good. There have been a few changes that will alter my present workflow so time will tell if those features have been improved or if its me that needs to get used to them. Quote Link to comment
MJasonM Posted September 24, 2012 Share Posted September 24, 2012 I am experiencing approx 3 second delay when changing sheet, editing viewports, extrudes, groups, etc.... very frustrating. I am going back to 2012 till this issues is resolved. I hope it is fixed soon. Quote Link to comment
Kevin McAllister Posted September 24, 2012 Share Posted September 24, 2012 I am experiencing approx 3 second delay when changing sheet, editing viewports, extrudes, groups, etc.... very frustrating. I am going back to 2012 till this issues is resolved. I hope it is fixed soon. Do you have the hierarchical display option for your classes turned on? Someone in another thread suggested turning that off speeds things up. Its probably worth a try. I have had some slowdowns as well. One was related to using the auto hybrid object, which I had placed in a symbol so there were multiple versions of it on the drawing. Things slowed down dramatically so I ditched it for a traditional hybrid symbol. Kevin Quote Link to comment
MJasonM Posted September 24, 2012 Share Posted September 24, 2012 (edited) thank you for the suggestion, but this did not solve the issue. I grabbed a stopwatch to get a more accurate time on the delay. Example #1 - In the edit viewport box, from hitting "OK" to being in a 3D wireframe viewport 10 sec Example #2 - In the edit viewport box, from hitting "OK" to being in a 2D plan view 9 sec Example #3 - Changing between sheet views 9 sec Example #4 - double clicking group to edit 5 sec These are significant delays. Any other suggestions???? Edited September 24, 2012 by MJasonM Quote Link to comment
Kimcz Posted September 24, 2012 Share Posted September 24, 2012 I am also experiencing ridiculous delays when editing groups, changing layers, viewports etc. 17 to 22 secs each time, which if editing groups is of course times 2- ungroup and group again. This is completely unworkable, so I am also ditching Vectordoesn'twork 2013 until the matter is sorted out. Surely the beta testers must have come across this problem. Nemetschek state than navigation is quicker. I think it is marginally quicker , but only if you don't have to change layers or edit groups or Viewports. Also, I found that the detail option, although very welcome, I have wanted this feature since Minicad6, is very slow and sticky. I have 4MB GB of RAM, but as XP is only 32 bit, this means that only about 3.2MB is available. Are Nemetschek trying to tell us that we have to upgrade to 64bit systems? This means all other programmes on your computer have to be upgraded. The cost!! I am going back to 2012, which also had many initial slownesses. Quote Link to comment
Dieter @ DWorks Posted September 24, 2012 Share Posted September 24, 2012 Are Nemetschek trying to tell us that we have to upgrade to 64bit systems? This means all other programmes on your computer have to be upgraded. The cost!! I am going back to 2012, which also had many initial slownesses. 32bit programs will work in a 64bit os. Quote Link to comment
Dieter @ DWorks Posted September 24, 2012 Share Posted September 24, 2012 Try turning off the 'feature' called 'Improved Navigation Graphics'. It's much faster here. Quote Link to comment
Dieter @ DWorks Posted September 24, 2012 Share Posted September 24, 2012 Feedback: Not worthy off the Evolve subtitle. Almost nothing off the features is usefull in architecture, and those that are are half-baked. I'm really dissapointed, though I still love VW. Quote Link to comment
Kimcz Posted September 24, 2012 Share Posted September 24, 2012 Thanks DWorks, I have switched off "Enhanced Navigation Graphics". I had already switched off the hierarchical display option. No improvement at all. Having gone back to VW2012 on the same file all the delay has evaporated. Quote Link to comment
Tom Klaber Posted September 24, 2012 Share Posted September 24, 2012 In the pase, we found that projects being upgraded from previous versions did not run as smoothly as projects started in the new version. It could be the translation of certain legacy objects are causing the lagging. I have not been using it in depth but in my playing around I have found it quite a bit faster than 2012. Quote Link to comment
Tom Klaber Posted September 24, 2012 Share Posted September 24, 2012 This feels like a minor release to me. The one big development for me and the firm I work for is the background rendering. Being able to continue to use VWs while rendering a viewport will be a huge time saver. Beyond that, there is not a whole lot to be all that excited about. Some of the other threads indicated that 2014 is going to be a more substantial upgrade. Maybe they are completing the migration away from Quicktime and to a 64bit program? Quote Link to comment
mike m oz Posted September 25, 2012 Share Posted September 25, 2012 Collectively though Tom there is quite a lot in Vw 2013: - the 3D improvements make working in 3D much easier and working in a perspective projection is now practical. - the Auto Hybrid Object is pretty neat if you create a lot of your own 3D content. - the Door and Window improvements are very good. - being able to select multiple PIO objects and edit them simultaneously is a good time saver. - the Roof tool is more robust and much quicker. - Surface Array expands the possibilities of what you can do organically in Architect. - the Space tool is improved. - Custom Line Types expands what you can represent. - being able to read and write DWF files is very handy. - the DWG export is better and being able to produce 2D DWG files from any Vw 3D view is pretty neat. - Rhino import and export expands the exchange possibilities. Also in every release there are always a raft of small changes and improvements that don't get much publicity. Vectorworks 2013 is no different and the more you use it the more you will find. Quote Link to comment
Vincent C Posted September 25, 2012 Author Share Posted September 25, 2012 Stability and compatibility? Quote Link to comment
Dieter @ DWorks Posted September 25, 2012 Share Posted September 25, 2012 In the pase, we found that projects being upgraded from previous versions did not run as smoothly as projects started in the new version. It could be the translation of certain legacy objects are causing the lagging. Then what to do with our big libraries? Starting over? Quote Link to comment
mike m oz Posted September 25, 2012 Share Posted September 25, 2012 Its been fine in the testing I've done. Quote Link to comment
Tom Klaber Posted September 25, 2012 Share Posted September 25, 2012 In the pase, we found that projects being upgraded from previous versions did not run as smoothly as projects started in the new version. It could be the translation of certain legacy objects are causing the lagging. Then what to do with our big libraries? Starting over? We do not maintain a central library of custom objects. We steal things from project to project, and in those cases we will jump into an old file and bring that object up. For all I know, that does not actually cause problems, and the performance issues were not from upgrading but simply from the complexity of the files. But my gut tells me that upgrading a series of interconnected complex files will unavoidably leads to some translation bug somewhere. Quote Link to comment
Vincent C Posted September 25, 2012 Author Share Posted September 25, 2012 The general rule is still to migrate as little as possible (which of course is fairly unacceptable in a program with a yearly upgrade cycle......). Quote Link to comment
Tom Klaber Posted September 25, 2012 Share Posted September 25, 2012 Collectively though Tom there is quite a lot in Vw 2013: - the 3D improvements make working in 3D much easier and working in a perspective projection is now practical. - the Auto Hybrid Object is pretty neat if you create a lot of your own 3D content. - the Door and Window improvements are very good. - being able to select multiple PIO objects and edit them simultaneously is a good time saver. - the Roof tool is more robust and much quicker. - Surface Array expands the possibilities of what you can do organically in Architect. - the Space tool is improved. - Custom Line Types expands what you can represent. - being able to read and write DWF files is very handy. - the DWG export is better and being able to produce 2D DWG files from any Vw 3D view is pretty neat. - Rhino import and export expands the exchange possibilities. Also in every release there are always a raft of small changes and improvements that don't get much publicity. Vectorworks 2013 is no different and the more you use it the more you will find. You are right, there are a few new tools - some of which will make work much faster, better, but this is not what I would call a major or bench mark release. Small tweaks like adding tilt turn to the window tool are nice, but should not be included in New Features of the program. For me the biggest thing, and it is not on your list is the background rendering. That is the type of significant change that is going to seriously effect workflow. If hidden line being faster or the space tool being improved is being called a new feature of the release, you know you are in an off year. 2014 Give Me: 64Bits Overhauled Usable Stair Tool Live Sections Revit Object Import Door and Window Type and Variations 2D Hatches on 3D Objects Overhauled Worksheets Electrical Tools Maxwell Plugin Quote Link to comment
ray isaacs Posted September 25, 2012 Share Posted September 25, 2012 i agree with tom. the new features are nice. but, if functionality is compromised by structural limitations in the software, which seems to still be the case, then new features don't mean very much. cheers, ray Quote Link to comment
Vectorworks, Inc Employee Hugues Posted September 25, 2012 Vectorworks, Inc Employee Share Posted September 25, 2012 Hello Kimcz, We haven't experienced the same delays here. Please submit a bug report and attach the file(s) so we can investigate. http://www.vectorworks.net/support/bugsubmit.php Thanks Hugues htsafak@vectorworks.net Quote Link to comment
MJasonM Posted September 26, 2012 Share Posted September 26, 2012 Submitting the bug was the first thing i did... I have been using VW since MiniCad 4.5... I love VW, but the first realease of each version is always buggy. For this reason I stayed with Ver 2008 till I went to 2012. Anyways, I look forward to the issue getting worked out, but for now, I am sticking with 2012 Quote Link to comment
Tom Klaber Posted September 26, 2012 Share Posted September 26, 2012 My colleague, who now has logged more hours than me in VW13, says he is seeing noticeably faster rendering times. Quote Link to comment
Kimcz Posted September 28, 2012 Share Posted September 28, 2012 "Please submit a bug report and attach the file(s) so we can investigate." How do I pass along a file of 92 MB The file works acceptably in VW2012. Quote Link to comment
ray isaacs Posted September 28, 2012 Share Posted September 28, 2012 kimcz, i use dropbox to send large files to vw tech support. seems to work well. ray Quote Link to comment
