I'm currently looking into standard naming (again) because many of my users aren't disciplined enough to work correctly with classes.
There are many things that can be done to make this standard naming a good usable thing:
(Correct me if I'm wrong on some things, I normally do not use standard naming)
1. We need the ability to specify the standard class for EACH object in VW, even custom plugins.
Like it is now, each object that uses a standard class, you can set through the plugin editor, but that's too time consuming and you need to do it with every release/update. A possible solution for this could be a list we can edit with the object name and it's standard class.
(More to follow as I'm going through this subject.)
Dieter @ DWorks
Edited by DWorksLink to comment
9 answers to this question
