Mat Caird Posted July 24, 2002 Share Posted July 24, 2002 I am having trouble selecting a locked layer link. Using the setup assistant I have created a massive set of layers and classes, and while trying to position my roof, I created a layer link to Floor Plan 3 Layer. Now I want to delete it, but I can't seem to select it? Layer and Classes are set to show/snap/modifyUnder the edit sheets dialogue, all the correct classes and layers are set to visible, and show/snap/modify is active for both layers and classes. Thanks for your help everyone Quote Link to comment
Mat Caird Posted July 24, 2002 Author Share Posted July 24, 2002 I now suspect I was getting confused with the actual layer, not a layer link...'cause pressing ctrl-alt-6 turns the thing off...I still don't understand why I cant select it when show/snap/modify others is on, but anyway.. Quote Link to comment
Mat Caird Posted July 24, 2002 Author Share Posted July 24, 2002 ctrl 6 , not ctrl-alt-6 sorry Quote Link to comment
Matthew Giampapa Posted July 25, 2002 Share Posted July 25, 2002 Layer Links are notoriously hard to select. If you know that you should be able to select it, but can't seem to get it. Try using the custom selection command in the Organize menu. You can build an expression "Kind is Layer Link" and use that to select them. Matthew GiampapaNNA Technical Support Quote Link to comment
Mat Caird Posted July 25, 2002 Author Share Posted July 25, 2002 THX for your reply!! Quote Link to comment
