Rendering Image Props
AndyBard
Hi Tasmin.
Thanks for getting back to me. Why would it render in open GL but not fast. Is open GL not technically renderworks?.
I have hopefully attached a file for you to have a play around with. I'm sure its probably something simple but after looking for so long I cant see the wood for the trees.
Thanks
Typical. Trust it to work on someone else s computer :)
Logically, I suppose that must mean a setting on my computer rather than the vw.
Another question.
If i'm in a hurry , I'll edit the image prop's render texture and tint the image. Turning a green phormium into a red one for example. In open GL the tint stays, in fast renderworks the tint goes.
This I assume happens due to the different systems that generate the render that you mentioned.
Linking back to the first problem, is there a preference menu or settings for the different types of render, or some guide lines on how the graphics card should be set up for VW?
Thanks.
  • 2 weeks later...
Hi all.
Please help.
Another issue which has occurred which must be linked to my original problem, which I have still not been able to fix.
Why would a texture show up in Fast Renderworks (FR) but not Open GL (OGL).
I understand from Tamsin that OGL uses the computers graphics card and FR uses a software, but what have I done in creating a texture/image prop that causes it to show up in one and not the other.
This computer has a Nvidia Quadro 4000, which i'm led to believe isnt too shabby.
Is there a setting for the graphics card that is linked to OGL? Any help is much needed, and very much appreciated.
Edited by AndyBard
Hello Andy:
Your original plant image prop renders fine for me as well in 2013. I don't see anything that may cause it to not render, except the gray other layers setting might cause textured objects to show as gray.
I can't guess what may be causing the second problem, you may try to post another VWX file.
