Richie Hatch Posted July 22, 2002 Share Posted July 22, 2002 I know that text tracking (intercharacter spacing) is not available in Vectorworks (as it is in every other package) but has anybody found a way of increasing the spacing between individual text characters without having to press the space bar.....? Quote Link to comment
canarch Posted July 22, 2002 Share Posted July 22, 2002 nope and just to make it more interesting pressing the space bar a number of times is not always the same for the next line. i always have a hard time alligning text this way regardless of wether the next line is within the same text box or a separate piece of text it will not allign simply by counting the number of space bar hits. all i can say is good luck. Quote Link to comment
RGyori Posted July 23, 2002 Share Posted July 23, 2002 Actually, there is relatively simple workaround. First insert a space between the selected letters then go back and individually select each new space and change its point size to some smaller (or larger) value. This will require some experimentation. Though not practical for large amounts of text, it works OK for titles and the like. Quote Link to comment
Guest Posted July 23, 2002 Share Posted July 23, 2002 When you say "every other package" do you mean every other CAD package? If so what package(s) are you refering to? Quote Link to comment
aersloat Posted July 24, 2002 Share Posted July 24, 2002 Yeah, really... kerning isn't even in all word processing packages, much less in most CAD packages. Quote Link to comment
PeterT Posted July 24, 2002 Share Posted July 24, 2002 Here's a method for adjusting text tracking, not too glamorous though. Create your text block in VW 8.5.2 file, copy it, and paste it into your VW 9.5.2 file. Each character will now be a separate text block, to be distributed as you wish. O.K,. not too practical, but it could be used in a pinch. Quote Link to comment
Richie Hatch Posted July 25, 2002 Author Share Posted July 25, 2002 When I say other packages I mean every other package that i work with. That includes Microstation, Photoshop, Quark, Illustrator, Word, Excel - need i go on. I also am fairly sure that it is available in AutoCad. Quote Link to comment
