The Hamma Posted August 22, 2012 Share Posted August 22, 2012 Below is a script by Peter Vandewalle and it work fine as a command or from the script palette but if I run it as a tool the angle constraints don't kick in to the second object duplication. Does any one know why and how to fix it. I like this script vs the move by point tool because it makes a duplicate object at every point that I click. and I don't have to keep switching the move by point from retain objects to not retaining objects. Procedure CopyPt; {Peter Vandewalle, 14-03-2003} LABEL 99; VAR ObjHdle,NewHandle:HANDLE; xi,yi,xm,ym,xp,yp,X,Y:REAL; YesNo:BOOLEAN; SelNum:LONGINT; Procedure do_error(s:STRING;v:REAL); BEGIN AlrtDialog(Concat(S,' = ',Num2Str(5,V))); END; BEGIN Absolute; SelNum:=NumSObj(ActLayer); IF (SelNum=0) THEN BEGIN Message('Select object to copy:'); GetPt(X,Y); SetSelect(PickObject(X,Y)); END; Message('Click reference point'); GetPt(xi,yi); YesNo:=false; xp:=xi; yp:=yi; REPEAT Message('Click endpoint, double-click to exit'); GetPtl(xi,yi,xm,ym); IF ((xp=xm) AND (yp=ym)) THEN GOTO 99;{Check 4 double-click} Duplicate(xm-xp,ym-yp); xp:=xm; yp:=ym; UNTIL YesNo; 99:ClrMessage; DSelectAll; RedrawAll; ClrMessage; END; Run(CopyPt); Quote Link to comment
WhoCanDo Posted August 28, 2012 Share Posted August 28, 2012 I have just copied and pasted this into a VS palette and the macro works fine. I have also copied and pasted it into a new VS Plug-in type Tool which also works for me. Can't offer a reason why it doesn't work for you though. Regards Quote Link to comment
