Alora Posted August 22, 2012 Share Posted August 22, 2012 I am designing a 2 story commercial building, which will have a large opening where the stairs will be located. I would like to show my clients a unified view isometric showing the stairs leading down to the ground floor. How do I create an opening in the floor? Quote Link to comment
CipesDesign Posted August 22, 2012 Share Posted August 22, 2012 I'm sure that the video posted shows this, but it's easy to make a hole in a Floor: draw the the shape of the hole (as a closed polygon or rectangle), then select the Floor and the Hole and use command Clip Surface. Then delete the Hole and Voila! Quote Link to comment
Alora Posted August 22, 2012 Author Share Posted August 22, 2012 That's exactly what the video showed and it worked like a charm? Is the procedure similar for making windows transparent? Quote Link to comment
taoist Posted August 22, 2012 Share Posted August 22, 2012 That's exactly what the video showed and it worked like a charm? Is the procedure similar for making windows transparent? What do you mean by transparent? Openings will show in walls in 2D and 3D modes. Quote Link to comment
Alora Posted August 22, 2012 Author Share Posted August 22, 2012 The windows do show up in the isometric but I want to be able to see through them. Quote Link to comment
michaelk Posted August 22, 2012 Share Posted August 22, 2012 Does the OIP say "window" or "window in wall"? Quote Link to comment
michaelk Posted August 22, 2012 Share Posted August 22, 2012 Also, check the window Settings, View tab. Make sure Glazing is set to clear. Quote Link to comment
Alora Posted August 22, 2012 Author Share Posted August 22, 2012 Glazing is set to clear but what is OIP? Quote Link to comment
Ozzie Posted August 22, 2012 Share Posted August 22, 2012 OIP = Object Info Pallette Quote Link to comment
Alora Posted August 22, 2012 Author Share Posted August 22, 2012 I use Object Info all of the time and the Windows are in Wall. Quote Link to comment
Tom G. Posted August 22, 2012 Share Posted August 22, 2012 Object Info Palette Make sure you have the window in the wall first of all. Sometimes we think the window is in the wall but it isn't. If you uncheck the Wall Insertion Mode* button (shows as not darkened) and try dragging the window off the wall, if it's in the wall properly, it won't come out. If it comes out with this lock on, it never was correctly in the wall in the first place. *first icon in the top most menu bar next to the (3) double headed arrows. Quote Link to comment
taoist Posted August 22, 2012 Share Posted August 22, 2012 (edited) Click on Settings in OIP Click on Classes Look near bottom for Glazing See image Edited August 22, 2012 by taoist Quote Link to comment
