Create Opening in Floor?
Alora
I am designing a 2 story commercial building, which will have a large opening where the stairs will be located. I would like to show my clients a unified view isometric showing the stairs leading down to the ground floor. How do I create an opening in the floor?
Object Info Palette
Make sure you have the window in the wall first of all. Sometimes we think the window is in the wall but it isn't. If you uncheck the Wall Insertion Mode* button (shows as not darkened) and try dragging the window off the wall, if it's in the wall properly, it won't come out. If it comes out with this lock on, it never was correctly in the wall in the first place.
*first icon in the top most menu bar next to the (3) double headed arrows.
