Counter top edge profiles
When you use the intergated tops, draw your reference path along centerline (midpoint) of depth of cabinet.
Current integrated symbol requires you to draw in a
counter clockwise manner.
Duplicate the symbol, edit, flip horizontal, exit.
Now you will have for both directions.
This is great for when you have cabinets that the sides do not butt to a wall and you want to have the side edge (left or right)of the countertop with a profile.
Current profiles are 1-1/2" thick so you need to edit profile, move bottom to rest on X axis, and have center of profile at junction of X & Y axis.
You will also need to set Z height to base cabinet height or whatever you need the countertop for.
See attached image for profiles.
Edited by taoist
