VWLP Posted August 2, 2012 Share Posted August 2, 2012 I am interested in creating keyboard shortcuts to recall some saved views I already have set up in my Vectorworks document. From some preliminary research it seems it could be accomplished using Vector Scripts, but I am a novice in this area and don't know how to create my own. Quote Link to comment
VectorGeek Posted August 7, 2012 Share Posted August 7, 2012 Hi VWLP, There is a VectorScript routine for recalling saved views: VRestore('VIEWNAME'); Technically, you could created a plug-in command (a one-liner using the routine above, replacing VIEWNAME with the name of your saved view) and place it in a menu, then add a keyboard shortcut. The issue is that if a view name changes (or you create additional ones), you'd have to edit the plug-in and/or create a new one each time. Cumbersome to say the least. You do realize that you can open a floating script palette with all saved views, and that you can access saved views from the pop-up menu in the mode bar? Both of these methods provide quick ways to choose a saved view. Using a KB shortcut may not be much faster.... Hope that helps. V-G. Quote Link to comment
VWLP Posted August 15, 2012 Author Share Posted August 15, 2012 VectorGeek, thanks for the solution. I was on a pretty similar path, but it just wasn't working until I tried your instructions. The type of work I do requires all my projects to use the same saved views, so it will save time to turn them into a quick keyboard shortcut. Very excited to set them all up now! Quote Link to comment
jrad Posted May 21, 2019 Share Posted May 21, 2019 Does anyone have an update on this? I'm trying to do this. Quote Link to comment
