Designer30 Posted July 31, 2012 Share Posted July 31, 2012 I am working on VW2012 educational version and seem to be missing the usual 'edit symbol' dialogue box when double clicking on a symbol. The dialogue box which usually asks if I want to edit the 2D or 3D properties of the symbol does not appear and instead - I am taken straight into editing the symbol (thus I cannot edit the 3D properties). Also, when I go to delete a class, the 'delete class(es)' dialogue box does not appear'. So I cannot 're-assign objects to another class'...it just deletes without asking. I'm sure this must be a basic settings problem and I would really appreciate any advice. Thanks Quote Link to comment
Dieter @ DWorks Posted August 1, 2012 Share Posted August 1, 2012 This is because of your preferences. There is a checkbox on these dialog boxes that, when checked, will save the action you want to do when and you will never get the dialog again. You can reset your preferences in the VW preferences. Then those boxes will appear again. For symbols: you can right click to go to the different parts of it. Right click is very powerfull and has more uses in the latest VW. Be sure to check every object out with right click! Quote Link to comment
Designer30 Posted August 2, 2012 Author Share Posted August 2, 2012 Thanks so much for this - right clicking works a treat for the symbols. I've looked at the VW preferences options but can't seem to figure out which option I should have selected to bring back the dialogue boxes...you don't happen to know which specific option it needs to be? Thanks again Quote Link to comment
Kevin McAllister Posted August 2, 2012 Share Posted August 2, 2012 Right click on the symbol. Choose Edit (not Edit 2D etc.). It will bring up the dialog box. Change the drop down there to the option you prefer to set the preference. Kevin Quote Link to comment
Dieter @ DWorks Posted August 4, 2012 Share Posted August 4, 2012 (edited) Thanks so much for this - right clicking works a treat for the symbols. I've looked at the VW preferences options but can't seem to figure out which option I should have selected to bring back the dialogue boxes...you don't happen to know which specific option it needs to be? Thanks again It's a button to reset your preferences. on the right side of the dialog. If I remember correctly, there are two buttons, it's the bottom one. Edited August 4, 2012 by DWorks Quote Link to comment
