grant_PD Posted July 26, 2012 Share Posted July 26, 2012 I know there's one out there somewhere...I used to know where. Does anyone have a script for this? Thanks Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted July 27, 2012 Vectorworks, Inc Employee Share Posted July 27, 2012 Hi Grant, Copy everything within the quote below and paste it into a script. This script only works with Class names and changes ALL class names (except "None" and "Dimension") in the active document. This could be modified to act on ALL Layer names in a document. Adding the ability to select only certain classes would be a bit more involved. HTH, Matt { Written by: Matthew G. Panzer PanzerCAD Services, Inc. 1997 } PROCEDURE ChangeClassNames; VAR Count: INTEGER; ClassName: STRING; PrefixStr: STRING; BEGIN PrefixStr := StrDialog('Add prefix(to all classes):', 'DWG-'); IF (ClassNum>1) AND YNDialog('This will rename all of your classes! Are you sure you wish to continue?') THEN BEGIN FOR Count := 3 TO ClassNum DO BEGIN RenameClass( ClassList(Count), ConCat(PrefixStr, ClassList(Count)) ); END; END; END; RUN(ChangeClassNames); 1 Quote Link to comment
