Roman Posted July 23, 2012 Share Posted July 23, 2012 (edited) 1) Copy geometry from Design Layer to Sheet Layer 2) You can still scale the geometry but you can't move it around. It still accepts global X & Y positions. Is this a bug, and if not how do I get to move copied geometry around? Edited July 23, 2012 by Roman Quote Link to comment
Benson Shaw Posted July 23, 2012 Share Posted July 23, 2012 I see the same in v2012. Objects pasted or reassigned from DL to SL cannot Drag, Move command, or Move by Points for location change, although can be moved with OIP coordinates. But move processes act as expected in v2011. Can't think of any advantage to this behavior. File a bug report! Good find. -B Quote Link to comment
Roman Posted July 24, 2012 Author Share Posted July 24, 2012 How do I file a bug, isn't this the place?!?! Quote Link to comment
Kevin McAllister Posted July 25, 2012 Share Posted July 25, 2012 Upper right hand corner of this forum screen, in the VW Community Links box, click on Bug Submit. Kevin Quote Link to comment
