Space Tool: ability to control visibility of boundary and label separately
Christiaan
I'd like the ability to control visibility of boundary and label separately.
For instance I want to be able to put the boundary line in the Guides class and my label on a different class but have the label visible when I turn the Guides class off.
As the moment the boundary class controls the overall visibility of the label too.
5 answers to this question
Christiaan,
As with all containers in VW the outermost class of the object if turned off will turn off all objects within the container. I assume the turning off of 2d boundary is not an option? You can set up a script to run that does this for all spaces at once. To solve the issue you present we place the objects on a class that can then be overridden in viewport with no fill and no pen making them appear off. Not sure what situation you need for this to occur.
Regards,
Stan
