Custom dialog
Does anyone know how to create a dialog with a number of choice that can be chosen from the dialog itself. (With a button "More choices" for instance.
The VW Criteria dialog is the perfect example (see attachment)
Another way to see it is a button that changes a the number of choices and resets the dialog. I cannot manage to do that.
Thanks,
As an alternative you could use tab panes to get to more choices. The first tab could show choices, the second tab could show additional choices.
Of course, If you want to add the choices one at a time and see them all at once, this alternative would not work.
