Offset Line / Code for a flashing tool.
Here is a function I wrote to create an offset polyline.
I draw flashings regularly. This code makes it easy.
All you need to do is set the thickness, use the Next Point to give a distance and angle and this will create a closed poly line.
PROCEDURE Offset;
{Code by Justin Wright 14 July 2012}
{Open to anyone cheers}
TYPE
Level1=Structure
hTemp: Array[1..4] of Handle;
GroupHandle:Handle;
RectHandle:Handle;
DirectionAngle:REAL;
END;
Var
ArrayStore:Array[1..10] of Level1;
PolyLocus:Array[1..100] of Handle;
iPolyLocus:Integer;
X1,Y1,X2,Y2:REAL;
ArrayPoint:Integer;
iCount:Integer;
iTotal:Integer;
Thickness:REAL;
bTemp:BOOLEAN;
PntA1,PntA2,PntB1,PntB2,PntIntersect: Point;
PROCEDURE NextPoint(LineLength,ObjAngle:REAL);
{This function creates a rectangle of locus points and stores the locus handels in an array}
{The array also stores the direction angle}
BEGIN
ArrayPoint:=ArrayPoint+1;
BEGIN;
BeginGroup;
Locus(0,0);
ArrayStore[ArrayPoint].hTemp[1]:=LNewObj;
Locus(LineLength,0);
ArrayStore[ArrayPoint].hTemp[3]:=LNewObj;
Locus(0,Thickness);
ArrayStore[ArrayPoint].hTemp[2]:=LNewObj;
Locus(LineLength,Thickness);
ArrayStore[ArrayPoint].hTemp[4]:=LNewObj;
EndGroup;
ArrayStore[ArrayPoint].GroupHandle:=LNewObj;
ArrayStore[ArrayPoint].DirectionAngle:=ObjAngle;
iTotal:=iTotal+1;
END
END;
PROCEDURE UsePointsMakeShape;
BEGIN;
{Get the hanel of each group of locus/ Rotate the group / Get the position of the previous group to move the current}
hRotate(ArrayStore[1].GroupHandle,0,0,ArrayStore[1].DirectionAngle);
{Get the position of a locus from previous group to move the current group into possition}
For iCount:=2 to iTotal Do
Begin;
hRotate(ArrayStore[iCount].GroupHandle,0,0,ArrayStore[iCount].DirectionAngle);
GetLocPt(ArrayStore[iCount-1].hTemp[3],X1,Y1);
hMove(ArrayStore[iCount].GroupHandle,X1,Y1);
End;
{Use the Locus in the group to find the intersetoin of the lines. Create a new set of locus which will become the polyline points}
{First Point}
PolyLocus[iPolyLocus]:=ArrayStore[1].hTemp[1];
{Cycyle up through the group to the the inside}
For iCount:=1 to iTotal-1 Do
BEGIN;
GetLocPt(ArrayStore[iCount].hTemp[1],PntA1.X,PntA1.y);
GetLocPt(ArrayStore[iCount].hTemp[3],PntA2.x,PntA2.y);
GetLocPt(ArrayStore[iCount+1].hTemp[1],Pntb1.x,PntB1.y);
GetLocPt(ArrayStore[iCount+1].hTemp[3],PntB2.x,PntB2.y);
LineLineIntersection(PntA1,PntA2,PntB1,PntB2,bTemp,bTemp,PntIntersect);
Locus(PntIntersect.x,PntIntersect.y);
iPolyLocus:=1+iPolyLocus;
PolyLocus[iPolyLocus]:=LNewObj;
END;
{Get the two end points at the top of the polyline}
PolyLocus[iPolyLocus]:=ArrayStore[iTotal-1].hTemp[3];
PolyLocus[iPolyLocus]:=ArrayStore[iTotal-1].hTemp[4];
{Cycle down the array to get the right hand side intersection points}
For iCount:=iTotal-1 downto 2 Do
BEGIN;
GetLocPt(ArrayStore[iCount].hTemp[2],PntA1.X,PntA1.y);
GetLocPt(ArrayStore[iCount].hTemp[4],PntA2.x,PntA2.y);
GetLocPt(ArrayStore[iCount-1].hTemp[2],Pntb1.x,PntB1.y);
GetLocPt(ArrayStore[iCount-1].hTemp[4],PntB2.x,PntB2.y);
LineLineIntersection(PntA2,PntA1,PntB2,PntB1,bTemp,bTemp,PntIntersect);
END;
{The final two points at the end of the poly}
PolyLocus[iPolyLocus]:=ArrayStore[1].hTemp[2];
{Now create a new poly line}
BeginPoly;
For iCount:=1 to iPolyLocus DO
Begin;
GetLocPt(PolyLocus[iCount],X1,Y1);
LineTo(x1,y1);
End;
EndPoly;
{Delete all the locus now note needed}
For iCount:=1 to iPolyLocus-1 DO
BEGIN
IF PolyLocus[iCount]<>NIL THEN DelObject(PolyLocus[iCount]);
END;
For iCount:=1 to iTotal-1 DO
BEGIN
IF ArrayStore[iCount].GroupHandle<>NIL THEN DelObject(ArrayStore[iCount].GroupHandle);
END;
END;
{Now create the actual Geometery of the Flashings}
PROCEDURE WINDOWHEad(FlashWidth:Real);
BEGIN;
NextPoint(5,45);
NextPoint(15,90);
NextPoint(FlashWidth,15);
NextPoint(35,90);
NextPoint(1,180);
NextPoint(5,-90);
UsePointsMakeShape;
END;
{***MAIN FUNCTION BODY***}
BEGIN;
iTotal:=1;
iPolyLocus:=1;
Thickness:=.55;
{To use the fuctions simply NextPoinst then usePointsMakeShape}
NextPoint(5,45);
NextPoint(40,90);
NextPoint(20,180);
NextPoint(30,90);
NextPoint(120,-10);
NextPoint(10,-45);
UsePointsMakeShape;
END;
RUN(Offset);
