Christiaan Posted July 10, 2012 Share Posted July 10, 2012 The brickwork texture in my elevations is not aligning between floors. Is this fixable? Quote Link to comment
taoist Posted July 10, 2012 Share Posted July 10, 2012 Christiaan, I can think of a couple of ways. May not be what you want though. Turn off the brick texture for lower Floor. Edit the upper storey wall texture/component downward to cover the lower floor walls. Don't use textures as part of the wall. Use extract surface then apply. Others may have an easier/better solution. Quote Link to comment
Joe-SA Posted July 10, 2012 Share Posted July 10, 2012 The Attribute Mapping Tool can change origins of textures in addition to hatches and planer objects. Likely not the universal solution your are looking for. Quote Link to comment
