nikolauz Posted July 6, 2012 Share Posted July 6, 2012 Hi, I am using vect. 2010 and I need to show for each room the total surface area. I drew different rectangles and merge them to have the correct shape. I see as property of my rectangle the total area surface on the property window. Is there a way to show that property on my draw? Thank you in advance. Nic Quote Link to comment
taoist Posted July 6, 2012 Share Posted July 6, 2012 (edited) nikolauz, Use the Space Tool instead. It is in the Building Shell Tool Set. Trace the areas you need to show the square footage. When you complete the trace it Auto reports the area. Click on the options button. You can control quite a bit. Edited July 6, 2012 by taoist Quote Link to comment
