[ASK]Vectorworks Designer Setting Limits and zoom all
Hi all,
I am relatively new to Vectorworks 2012. Maybe this already been posted somewhere, but I just can't find it.
Just straight to my problem.
I can't figure out how to set limits (workspace size) in Vectorworks. I just moved from AutoCAD, which has command "limits". Why I ask this because when I zoom out, my drawing disappears, and it really hard to locate it, somewhere in the workspace.
I use MacBook Air, 1.8GHz intel i7 with 4GB DDR 1333 MHz
OS Snow Leopard 10.7.3
Thank you,
Kumoro
The best way to draw is around the center/origin of the document, and never move this origin to avoid problems.
Take this advice!
Using real life coordinates is an Autodesk thing but usually leads to problems in all other CAD apps (incl. Revit!)
In addition to this if you need to do perspective views you will have large problems if you are not drawing near the origin.
I usually keep one file (with for example my situation) that has the correct orientation and coordinates, which if needed can be used as an xref or can be xrefed into.
