mritchey Posted June 28, 2012 Share Posted June 28, 2012 (edited) Hey Everyone, I am trying to insert lighting positions from the resource browser, but when I import them nothing is displayed. I can select the object, and it tells me that it is a 2D/3D Symbol and I am able to edit it, but I cannot actually see it (plan or 3D views). I'm sure it is something that I did by mistake, but I have no idea what. Any help would be greatly appreciated! Thanks, Mike Edited June 28, 2012 by mritchey Quote Link to comment
Farookey Posted June 28, 2012 Share Posted June 28, 2012 Hi... Ensure all the correct classes are turned on. Can you see the geometry when you edit the symbol? Send a file over with such an issue. I'll check it out. Quote Link to comment
mritchey Posted June 28, 2012 Author Share Posted June 28, 2012 It turns out in my Template (and most of my files) I had the class "None" turned off. Of course, even if you assign the object to a different class, some part of it is still assigned to "None." Since I had the visibility turned off, it would not show up. But as soon as I turned the "None" class on, it worked right away! Quote Link to comment
