Yoginathaswami 0 Posted June 24, 2012 Aloha, I made several extrusion while in the Front view. Then, I switched to Right view and tried use the Duplicate Array command; however, the duplication keep happening on the X axis of the Front view. I tried changing the planes but no luck. The planes still is puzzle to me! I am probably missing something simple here. See attached jpeg. Please help! Thanks Quote Share this post Link to post
Jonathan Pickup 290 Posted June 24, 2012 Try adjusting the Y distance, with 0 for the X Quote Share this post Link to post
Yoginathaswami 0 Posted June 30, 2012 Thanks Jonathan! I solved it...I needed to change one setting in the Duplicate Array dialog box. "Values Are With Respect to the?Working Plane" the default setting was "Layer Plane." That did it! Quote Share this post Link to post
