alfie hope Posted June 15, 2012 Share Posted June 15, 2012 Is there a way to change the default rotation of a door? (or a window for that matter?!) The idea is to be able to change the orientation WITHOUT having a rotation value under the object info because this messes stuff up when exporting to IFC and also causes other problems within vectorworks!! ggrrr Alfie (obviously you only actually get to view the rotation when the door is not inside a wall) Quote Link to comment
