reh577 0 Posted June 13, 2012 Sorry for the newbie question, and hoping the community can help. I'm trying to use the hardscape tool to create two pathways in Landmark: 1. Irregular width curved pathway with a border on the sides, but not top or bottom, with a 4x8 basketweave paver fill. I can get the fill and border, but since I'm working in boundary mode due to the irregular width, there doesn't seem to be a way to limit the border to only the sides of the path. Am I missing something or is there a work around? 2. Curved path with running bond hatch fill, no border - how to get fill to follow curves of path? Or is this a job for another tool? Renee Quote Share this post Link to post
Monadnoc 3 Posted June 13, 2012 For 1) just hide the edge of the hardscape/polyline. Double click to edit the Hardscape, then use the Hide or Show edges mode of the Polygon Reshape Tool (fifth mode button in) and click on the center handle of the edge you want to remove the border from. Can't answer 2). 1 Quote Share this post Link to post
reh577 0 Posted June 13, 2012 Thanks much for the prompt reply Monadnoc - that took care of the border problem. Hopefully someone else out there will know how to address question 2. R. Quote Share this post Link to post
Bryan G. 29 Posted June 13, 2012 You need to create a shape for the paver you are using. then draw (offset lines that are the width of the paver you are using. Then use the duplicate along path command to place multiple copies of the paver in running bond rows. A better tool for this would be great! 1 Quote Share this post Link to post
Tamsin Slatter 248 Posted June 13, 2012 That's right - it would be so cool if we could fill a hardscape with a pattern that follows the flow of the pathway. Another way to do it, would be to use the Wall tool for the pathway (a wide, very low wall) and create a tile fill that is set up to both rotate in wall and fit to wall. The basic tile pattern will stretch along its Y axis to fit the wall, so you will have to be careful that you draw it so it doesn't distort, but it will then rotate along the curve. Of course, you then lose the benefit of the hardscape having automatic edging, but you could use two other walls to create the pathway edging. Hope that helps! Quote Share this post Link to post
reh577 0 Posted June 13, 2012 Thanks Bryan & Tamsin. I did try the duplicate/offset, and with some work on the spacing that turned out well enough. I will give the wall tool a try as well. Renee Quote Share this post Link to post
Bryan G. 29 Posted June 14, 2012 Good option Tamsin, I haven't tried that yet. I'll give it a whirl. Quote Share this post Link to post
Ozzie 17 Posted June 14, 2012 Hardscape Tool Basic???? it would be so cool if we could fill a hardscape with a pattern that follows the flow of the pathway It would also be cool if the Hardscape Tool produced decent corners when using a spaced border - it does not!!!! Consequently this project with lots of townhouses I could not use it and for each house had to do these by hand - takes a lot of time The Hardscape Tool still requires a big fix up; we need a tool that works not work arounds Quote Share this post Link to post
Bryan G. 29 Posted June 17, 2012 Yes Ozzie I agree, Also the ability to create a plane with more that one slope easily. Handles on the hardscape would be perfect. 1 Quote Share this post Link to post
Michal Zarzecki 10 Posted June 19 Hi All. Interesting ideas and solution above. Will definitely need to try these out. When using the Hardscape tool for the first time I felt that the tool needs a bit of love. I think that it's not only about the visual aspect, but also the specification. I was quite surprised that the information in the tag was so limited. It would be amazing, if one could not only define the visual side of things but also the technical one. Imagine there are fields where you detail the proposed manufacturer, jont width, perhaps mortar etc and this is then automatically included in the tag. The latter could be styled, i.e. one could choose what item of the spec to include. Another thing is the edging discussed in this thread. Perhaps one could define the profile of edging, similarly to the possibilities offered by the Railing tool. So, imagine you have a default choice of BS kerbs, block eding, setts and you can add your own. And the concrete bedding and haunching as well 🤩 . What do you think about it? 1 Quote Share this post Link to post
bgoff 66 Posted June 20 I would attach a record format that is custom generated to the specs you want, and use that for all specs. This process works great for Turf, Edging, Mulch, Walls, Lighting, Etc.. 1 Quote Share this post Link to post
Michal Zarzecki 10 Posted June 20 @bgoff , that sounds promising. I need to try out how that works. Quote Share this post Link to post
bob cleaver 20 Posted June 21 @bgoff can you develop some samples in a VWX file and share it ? 1 Quote Share this post Link to post
bgoff 66 Posted June 21 Yes I will, Hang in there and I will try to get these out soon. 3 1 Quote Share this post Link to post
