sicily80 Posted June 28, 2002 Share Posted June 28, 2002 Hi! I am having difficulty exporting a jpeg for a page layout. how do you select what to export? Quote Link to comment
StarGate Posted July 1, 2002 Share Posted July 1, 2002 Hello, I tried a couple of months ago to export a VectorWorks drawing in jepg format. If you do nothing and draw everything on the same layer, everything will be exported. I did not try it yet, but put the objects you like to export on a separate layer. Make only that layer visitble and active. Now choose export and format jepg. Does that work? On this moment I do not have VectorWorks. I will try it this evening and give you a message. With friendly greetings, StarGateemail : kristiaan.verberne@skynet.be Quote Link to comment
Guest Posted July 1, 2002 Share Posted July 1, 2002 Generally, anything you see on the screen will get exported. If you only have one layer active, only those items will be exported. The one trick is if you use the Perspective picture frame to frame the portion of the drawing you want to export. In this case, only the things inside the picture frame will export. Quote Link to comment
sicily80 Posted July 3, 2002 Author Share Posted July 3, 2002 Great! Thanks for the info. I'll try it out. Quote Link to comment
