PeterT Posted May 29, 2012 Share Posted May 29, 2012 Can anyone help explain how to delete a symbol definition from a file? I have tried using both - DeleteResourceFromList (fldrlist,symindex); and -DelName(symname); and neither one deletes the symbol defs from the resource browser. Here is the subroutine that I thought should delete the symbol definitions using DeleteResourceFromList: PROCEDURE DeleteOldSyms; VAR fldrlist, numitems,symindex : LONGINT; symname : STRING; BEGIN fldrlist := BuildResourceList(16,0,'',numitems); FOR symindex:= numitems DOWNTO 1 DO BEGIN symname := GetNameFromResourceList(fldrlist,symindex); IF (symname = 'Old Symbol 1') OR (symname = 'Old Symbol 2') THEN DeleteResourceFromList(fldrlist,symindex); END; END; Does anyone know what I am doing wrong? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 29, 2012 Vectorworks, Inc Employee Share Posted May 29, 2012 DeleteResourceFromList just removes the symbol from the list. If you want to delete the object you need to use DeleteObject(); SymHand := GetObject('Old Symbol 1'); {You should do some other checking here to make sure it's a symbolo def} If SymHand <> NIL then DelObject(SymHand); Quote Link to comment
PeterT Posted May 30, 2012 Author Share Posted May 30, 2012 Thanks I will try that. But just curious, how can you delete a resource from the list without deleting the resource itself? If the resource is in the file, doesn't it have to be in the resource list somewhere? So I guess the next question follows. To get rid of the resource (from the file) do you have to both delete the resource using DelObject AND delete the resource from the list using DeleteResourceFromList? If not, then when would you use DeleteResourceFromList? Quote Link to comment
Pat Stanford Posted May 31, 2012 Share Posted May 31, 2012 The resource list is just that, a list of the resources in the file (or in some library file) depending on how you created the list. You can use the VS routines to add to and subtract from that list as you see fit. For example you could get a list of all the symbols with the name chair and then remove all the ones that included rocking as part of the name. This would not change the resources in the file, only those that will be acted on my the list. When you delete the actual resource it is automatically deleted from the list (I think, test for Nil handles before trusting me on this), or at least will not be able to be built into a new list. HTH Quote Link to comment
PeterT Posted May 31, 2012 Author Share Posted May 31, 2012 So I guess to try and understand it better, it seems you could say that DeleteResourceFromList only deletes the the resource from the list during the current running VectorScript, so you can perform actions on a custom tailored list. But when the routine completes, since the actual resource is still in the file, the resource will appear in the list again if you build the same list in a new routine. Does that sound right? Quote Link to comment
Miguel Barrera Posted June 1, 2012 Share Posted June 1, 2012 To delete the symbol definitions try this code: PROCEDURE DelSymDef; {DEBUG} CONST kSYMDEF = 16; kSYMFDR = 92; kSUBSTR = 'Old Symbol'; VAR curSymDef: HANDLE; PROCEDURE SearchSymDef(curDef: HANDLE); VAR delSym: BOOLEAN; symType: INTEGER; symName: STRING; symDef1,delDef: HANDLE; BEGIN WHILE curDef <> NIL DO BEGIN symType:= GetType(curDef); IF symType = kSYMFDR THEN BEGIN symName:= GetName(curDef); symDef1:= FInFolder(curDef); SearchSymDef(symDef1); END ELSE BEGIN symName:= GetSDName(curDef); delSym:= (Pos(kSUBSTR,symName) > 0); IF delSym THEN BEGIN delDef:= curDef; curDef:= PrevSymDef(curDef); DelObject(delDef); END; END; curDef:= NextSymDef(curDef); END; END; BEGIN curSymDef:= FSymDef; SearchSymDef(curSymDef); END; Run(DelSymDef); Note that the code does not check if symbol instances are still in the drawing before deleting the definitions. I assume you will get a locus at the symbol origin and/or a corrupted file if the instances exist. Quote Link to comment
