Unconstrained dimension tool
When using the unconstrained dimension tool, if you pan (hold the space bar down) in the middle of dimensioning, the tool seems to stop working correctly. Has anyone else experienced this?
Using VWA 9.5.1, Win98
Thanks
Brett
What happens to the dimension?At what step in the dimensioning do you switch to the pan tool ?
I notice that if you use the unconstrained dimension tool, click on one end of the object, then the other, switch to the pan tool, then go back to double click to place the dimension, then nothing appears. This also happens in VW 9.5.2.
Is this what you are experiencing?
I am going to look into this.
[ 06-25-2002: Message edited by: Katie ]
