Draw line from locus?
Nobody? I've wanted this function on several occasions. But I see some problems:
Where is the start, the end? User defines with clicks? Closed loop?
In what order shall the points be connected? Shortest path? Angle or radius limit?
If making a NURBS curve through the points, can some be left out if they are way off?
But there should be many situations where this idea could be applied.
-B
