BIM Failure
On 6/23/2012 at 7:25 PM, Robert Anderson said:
There is no "Slab Area", but there is "area()" which works with a slab object. Please review the worksheet in the very first 'quantify.VWX' document I posted above. (I fear we may be discussing in circles?)
Is there any way you could direct me to this post?
On 6/22/2012 at 11:52 PM, Assembly said:
I can easily create a Database row and get a list of all wall styles and the related area.
Cell 1 '=WST' [sum]
Cell 2 '=WALLAREA_NET'
This is how easy it should be.
To make it easy I should continue and
Cell 3 =('__NNA_Wall_Style_Format'.'Cost Index Code')
Cell 4 =A2*A3 and I will have an estimate of cost for all the walls.
Now I try the same for slab. I can't see any way to emulate the same set up for slabs as I can for walls.
There is no similar 'SlabArea'
'=WST' does not have a corresponding '=SST'
I am able to get a read out from this method for everything except the Cell 4 which would be the resulting cost estimate shows #value. Any ideas what I am doing wrong?
