Cannot select multiple objects
All of the sudden, I cannot select more than one object by using the shift key. Played with class and layer options, restarted Vectorworks, tried older files that were fine, played with selection tool options. Nothing works. I can select with a marquee, but then cannot unselect single objects from groups of selected objects either. The option-select is not working either. Yikes! What is going on here?
First thing I checked was the Mode bar. I have since done all options on the Mode bar just for good measure. I have also discovered that option-dragging does not work anymore either (should give me a duplicate object). So, I have tried a different keyboard too. Nothing.
  • 3 months later...
