Greg Miller Posted May 23, 2012 Share Posted May 23, 2012 All of the sudden, I cannot select more than one object by using the shift key. Played with class and layer options, restarted Vectorworks, tried older files that were fine, played with selection tool options. Nothing works. I can select with a marquee, but then cannot unselect single objects from groups of selected objects either. The option-select is not working either. Yikes! What is going on here? Quote Link to comment
VincentCuclair Posted May 23, 2012 Share Posted May 23, 2012 Check the mode bar, you need to have the third option activated. Quote Link to comment
Greg Miller Posted May 23, 2012 Author Share Posted May 23, 2012 First thing I checked was the Mode bar. I have since done all options on the Mode bar just for good measure. I have also discovered that option-dragging does not work anymore either (should give me a duplicate object). So, I have tried a different keyboard too. Nothing. Quote Link to comment
bc Posted May 23, 2012 Share Posted May 23, 2012 Try changing to another workspace? Quote Link to comment
CipesDesign Posted May 23, 2012 Share Posted May 23, 2012 Restart VW's and restart computer. Usually these types of issues will cure themselves during restart... Quote Link to comment
Tom Klaber Posted August 30, 2012 Share Posted August 30, 2012 Same exact problem. I am flummoxed. Quote Link to comment
Jonathan Pickup Posted August 30, 2012 Share Posted August 30, 2012 do you have a web browser running? If so, close it. Quote Link to comment
