Nathan@HPI Posted May 22, 2012 Share Posted May 22, 2012 I have an area that I am trying to make fill with a stone hatch; however when I choose the hatch it appears exploded on the screen, simply a bunch of jumbled lines. In other drawings and files it shows up correctly. I am thinking it is something related to the origin and being too far from the origin, but am not sure how to resolve the issue. Has anyone had this problem of know how to fix it? Thanks! Quote Link to comment
Benson Shaw Posted May 22, 2012 Share Posted May 22, 2012 Could this be an issue with the scale of the hatch or the layer it's on? Try increasing or decreasing scale in the hatch dialog. To investigate problems with distance from origin, draw a test object at the origin and apply the hatch. Duplicate the file and test on the dupe if there are concerns about altering this drawing. Did the drawing origin move from the default 0,0? If so, can it be reset? Can the entire collection of objects be moved closer to the origin? Maybe by pasting into a new file with some kind of registration monument placed in each layer? Viewport crops will need to be moved by same amount. -B Quote Link to comment
